Hot Keys ask
When you say "hot key" do you mean programmable key?Lee Justice0
yes0
You would need to make an interrupt, and in the corresponding trap routine use a user prompt to enter the integer value.Lee Justice0
I created a function on 4 keys, I have a signal, but I can't make a choice. I tried to edit "BackTask" I restarted the controller but it doesn't work for me.
my changes in "BackTask"
IF OpMode() = OP_AUTO THENIF Doutput(doProgramKeyP1)=1 and doutput(doTache1EnCycle) = 1 ViewerAuto;IF Doutput(doProgramKeyP2)=1 ChoiceLanguage;IF Doutput(doProgramKeyP3)=1 ModeRobot;IF Doutput(doProgramKeyP4)=1 Zmena_Vysky;
...PROC Zmena_Vysky()sHeader:=strgfile{34};sListView := [[" ",strgfile{27}],["",""],["",""]];btnButton:=btnOKCancel;Icon:=iconInfo;ListView sListView,sHeader,btnButton,icon,nMaxTime;IF nChoice=1 THEN!!!!!!!!!!!!Possition 0PERS num vyska:=0;TPWrite strgfile{1};TPWrite strgfile{27};PROC zmena_vysky()PulseDO\PLength:=0.5,c1DropWobj;PulseDO\PLength:=0.5,c1RemAllPObj;ENDPROC
can you help me,what i working bed?
I need it to be able to change in automatic mode without interrupting the cycle.
I do not see anything that would set the value for nChoice. Perhaps you mean to use UINumEntry.Lee Justice0
i sended message for you.0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
