How to change status I/O signals on the OPC UA Client side?
OPC Client connected to the IRC5 OPC UA Server, I got I/O status signals, but I am not able to change the state of any I/O item. Any help is appreciated.
It works, sorry. Problem was in Security Policy1
Hi, im just curious
What do you use as a OPC Client?
It does not matter. It is just OPC industrial protocol. You can use any or develop by yourself.0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
