problems with reltool...
hi people.
I made the following program...
MODULE TESTE
VAR robtarget p10;
VAR num AngleZ;
PROC main()
p10:=[[863.28,-0.43,1370.4],[0.048771,0.000397,0.99881,-0.000257],[-1,-1,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
MoveJ p10,v500,z50,tool0;
anglez:=0;
Begin:
waittime 0.5;
AngleZ:=angleZ+10;
MoveJ RelTool(p10,0,0,0Rz:=AngleZ),v500,z50,tool0;
GOTO Begin;
however, when angleZ is greater of 120? i have got a following error
The desired position cannot be reached with the given robot configuration.
How can i resolve my problem to make a rotation of 360 without change the position of the robot in the program?
Sorry about my english...
Turn off Configuration check
ConfJ /OffPer Svensson
Consat Engineering0 -
Thanks PerSvensson...
companheiros estou precisando gera minha licen?a da minha abb serial 60123 aguardo respostas ok0
Your welcome
Be aware of that if you turn of configuration the robot always take the closest way (axis 1,4,6,) and in some cases you may not want that to happen. So be carefull when you run with configuration off.Take a look in the manuals around configuration, good to know how this works and if you are working in RobotStudio it's even more important at least if you are creating target out of a geometry.
But of course in RobotStudio you can play around without messing up the real hardware.
Per Svensson
Consat Engineering0
- 361 IRC5
- 78 OmniCore
- 853 RAPID Programming
- 30 AppStudio
