trigger num/dnum
Is it possibile to set a num variable at the middle of the corner path?
With TriggJ/MoveJGo instructions I can only set DO/GO.
Other idea is to use MoveLSync but I can't use procedure with argument
  • Maybe I am misunderstanding, but why can't you use MoveLSync? It allows you to trigger a procedure, just like this:
    MoveLSync p2, v1000, z30, tool2, "my_proc;"
    The proc could be as simple as setting your num/dnum to your desired value.
  • I would like to give some positions a number with is triggered in the point (without stopping robot)
    If I use:
    I need to create as much procedures as points.
    The solution could be to call procedure with argument:
    MoveLSync p2, v1000, z30, tool2, "my_proc(55) ;"
    Proc my_proc(num number)
      PosNumber:=number;
    EndProc
    But this doesn't work.
  • Check out triggiosdnum in the Technical Reference Manual  page 1711
  • It wouldn't work.
    According to the manual:
    triggiosdnum is used to define conditions and actions for setting a digital output signal, a group of digital output signals or an analog output signal at a fixed position along the robot’s movement path.
    The only solution what I see is to create Virtual GO and use MoveJGO
  • xerim
    xerim
    edited January 2021
    I think you can convert analog output signals to a number.
    VAR num my_num;
    my_num:=AOutput(AO_signal);
