trigger num/dnum
Maybe I am misunderstanding, but why can't you use MoveLSync? It allows you to trigger a procedure, just like this:
MoveLSync p2, v1000, z30, tool2, "my_proc;"
The proc could be as simple as setting your num/dnum to your desired value.
I would like to give some positions a number with is triggered in the point (without stopping robot)
If I use:
I need to create as much procedures as points.
The solution could be to call procedure with argument:
MoveLSync p2, v1000, z30, tool2, "my_proc(55) ;"
Proc my_proc(num number)
PosNumber:=number;
EndProc
But this doesn't work.
Check out triggiosdnum in the Technical Reference Manual page 17110
It wouldn't work.
According to the manual:
triggiosdnum is used to define conditions and actions for setting a digital output signal, a group of digital output signals or an analog output signal at a fixed position along the robot’s movement path.
The only solution what I see is to create Virtual GO and use MoveJGO0 -
I think you can convert analog output signals to a number.VAR num my_num;my_num:=AOutput(AO_signal);0
- 365 IRC5
- 84 OmniCore
