Function WaitWObj not found
I have created in the past some Solutions using this function without any problems. But now every time I create a new solution, this function is not available.
Im using the IRB 5400 + conveyor tracking with RS 6.05 (robotware 6.05 also)
As you can see I have created the conveyor, then created the connection and added an object to it. The object was placed on the conveyor and attached..
But when I try to wait for the object, WaitWObj is not where it used to be.
Thank you in advance
  • That is strange, it should be added automatically if 606-1 Conveyor Tracking is available. How did you create the controller?
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Kienan123
    Kienan123
    edited January 2021
    You will need to add it under Home>Path programming>Edit instruction templates.
    "Edit instruction templates" it the tab to the right of "Path Programming"
