Time Synchronization for the robot doesn't work
Dear friend,
I set the "Time Server" IP (it's a computer) for the robot and the robot's time is differ much (more than 1 year) to the Time server.After setting for a long time, the robot's time doesn't synchronize.
How to make it works?Is it possible to make it works by PC SDK code?
Thanks a lot.
  • What version of RW? CMOS battery in controller could be dead, I would try to replace and see if that fixes the issue.
    RW version is 6.08.CMOS battery is ok.I have set the time server IP to the robot controller, but I don't know how to triger the synchronize action, or it will synchronize automatically at some time?But I wait for a long time, it still not synchronize.
  • I think the LAN port needs a different subnet than the WAN, see below
    Do you have it configured this way?
  • Dear xerim,
    I connect the controller with WAN port.Is there any different setting?
    Thanks.
  • xerim
    xerim
    edited February 2021
    What happens when you try this?
    How long until the controller loses the correct date and time?
    I didn't try setting on TP.I set the NTP server IP and time zone by webservice api.I have checked the setting is correct.And the robot time is about 1min20sec difference to the NTP server.But the robot didn't time sychronize.
