Time Synchronization for the robot doesn't work
Leon_dev
Dear friend,
I set the "Time Server" IP (it's a computer) for the robot and the robot's time is differ much (more than 1 year) to the Time server.After setting for a long time, the robot's time doesn't synchronize.
How to make it works?Is it possible to make it works by PC SDK code?
Thanks a lot.
Thanks a lot.
What version of RW? CMOS battery in controller could be dead, I would try to replace and see if that fixes the issue.0
xerim said:What version of RW? CMOS battery in controller could be dead, I would try to replace and see if that fixes the issue.
I think the LAN port needs a different subnet than the WAN, see below
Do you have it configured this way?0 -
What happens when you try this?
How long until the controller loses the correct date and time?0 -
xerim said:What happens when you try this?
=。=!0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
