Wondering why my external axis data goes into the wrong place when I synchronize to Rapid?
cdavison
When I synchronize all the external axis data looks like this [0,0,90,20, 9E+09, 9E+09] and I have to convert it using a text editor to look like this [9E+09,9E+09,9E+09,90,20,9E+09].
My understanding was ( [9E+9,9E+9,9E+9,9E+9,9E+9,9E+9] = [Logical Axis 7, Logical Axis 8, Logical Axis 9, Logical Axis 10, Logical Axis 11, Logical Axis 12] )
So I went to RAPID>Motion>Joint> and then changed the logical Axis from :
Name Logical Axis
M1DM2 9
M2DM2 10
M7DM1 7
M7DM1 8
to what you see below . Once I did that I could not get the robot to move to any position unless it was a MoveAbsJ (with wjob0) . And even then it says Logical axis 11 has no value. I'm still learning so layman's terms is appreciated.
Thanks Chris Davison
Are you activating your mechanical unit with ActUnit() in your program?0
Yes I am. I'm not sure if its relevant but on RS the unit is called dcgauche and on the actual robot its called STN20
Do the coordinates for the external axis in the linear jog tool in RS match that in the FlexPendant?0
Sorry but I'm not sure how to check that to be honest.0
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
