Controller options Profinet fieldbus adapter
Dear friends,
I am currenty working on a project where i have to eshablish abb plc comunication. I would like to use Profinet fieldbs adapter.
I have main computer 639 with RobotWare 5.16. However i cant see the profinet option in my system.
How can i add this option to my system?
I tried to modify my system to ad new option. But profinet fieldbus is not in the list. Please help this hopeless student ...
Hello.
To add options to a real controller you need the correct license key, Please contact you local ABB if you want to purchase additional options for your controller.—Nils OlofssonPC Software Support Engineer0 -
Hey Nils,I have application manual of Profinet field bus adapter. Here it does not say anything about license key.Also, I am trying to add this function without mounting the Profinet adapter on computer. So i actualy have no profinet hardwareDo you think is that might be a problem?0
You should be able to add the option once you have the license for it.
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
