How to use abb_robot_driver with robotStudio
dyu
I'm trying to setup this ROS driver to be used with RobotStudio.
- How can I set up a virtual controller that works with this and has EGM support
- Where can I find the controller's ip address?
IP address for the controller can be found if you click the ABB icon in the top left then System Info>Controller Properties>Network Connections>Service Port0
Thanks for your reply, I got the IP address from the virtual Flex Pendant -> Controller Properties -> Network Connections -> Service Port.
When I try to run "ping <ip_address>" I get "request timed out" messages. To be able to make contact with the driver I need this to work. How can I fix this?Post edited by dyu on0 -
Maybe it is being blocked by a firewall?0
