How to access FTP from RobotStudio
Hello all
try to connect to my FTP server on the same machine as robotstudio with no sucsess.
Load\Dynamic,"MyFTPServer:"\File:="main.mod";
Under Motion Configuration i have:
- 614-1 FTP-Client
- 615-1 NFS Client
- 616-1 PC Interface
under Configuration-Communication I have the correct IP address (192.168.0.192). Tried 127.0.0.1 and localhost - nothing.
When I connect from a "real" controller (running robot) it works perfect - so my FTP Server is OK.
Any ideas?
Thanks!
I've never had any success with the FTP-Client option in RobotStudio, connecting with an application like FileZilla however seems to work with no issues.0
I have problems with FileZilla.working:-vsFTP (Debian)- own Java FTP-Server (Windows/Debian)not working:- FileZilla (Controller doesn't seem to send the password)- own C++ FTP-Server (instead RETR command controller send LIST command)I tried several FTP-Clients to access a file from my C++ FTP-Server (integrated into my software) and they all work. So username, password, IP etc must be correct.Maybe if you could share the settings of your FileZilla-Server could lead me to the solution?Thanks!0
When I login via FileZilla I don't use a username/password, leaving it blank works just fine. I am using RW 5.15 though0
OK, I'll try. I have same RWHere what I get:(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> Connected on port 21, sending welcome message...(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> 220-FileZilla Server 0.9.60 beta
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> 220 Please visit https://filezilla-project.org/
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> USER abb
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> 331 Password required for abb
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> PWD
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> 530 Please log in with USER and PASS first.
(000042)2021-03-16 9:24:22 AM - (not logged in) (192.168.0.100)> disconnected.
(000043)2021-03-16 9:24:25 AM - (not logged in) (192.168.0.100)> Connected on port 21, sending welcome message...
hmm - are you using FileZilla as a client to access the controller or the Server to access FROM the controller to the FileZilla FTP Server?0
Access the controller0
ok, I try the other way. Thanks anyways!
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
