Data not being shown in client from OPC UA Server
stefpender
edited April 2021 in IRC5
I've been using the OPC UA server for months now with a virtual controller setting up communications.  Today I'm getting error messages "Error creating monitored item on server."  I tried updating the OPC UA server and RobotStudio.  Using Softing DataFEED client as the manual recommends.  Any ideas?
  • Uninstalled and reinstalled everything.  It's working now!
  • user_matiss
    edited November 2021
    Good day! I have been using virtual controller IRC5 and OPC-UA server in RS2021 actively for the last few months. This is a task for students to do connection with UAExpert client. We have a lot of issues  for controller tags  of Rapid variables and I/O signals not showing up on the opc client side. Usually this works only after several re-starts and recreation of robot alias in the server.
    Is this somewhat related to the virtual controller? Othervise this is a production-like setup.
  • Thanks for sharing your issue and updating. I'm trying the IOT Gateway against an older version of robotware (6.05.02) and only get PERS variables (no VAR or CONST) -- perhaps I need to try some re-installs.
  • Maxim Riabichev
    edited December 2021
    user_matiss After creating a persistent variable on the controller, you have to restart the IoT Gateway for it to show up in the client. Same goes for when you delete a variable from the controller.
    XNOR According to the manual https://robotapps.blob.core.windows.net/apps/ApplicationManual IoT Gateway v1.1.pdf
    I.e. only persistent variables are available from the RAPID domain.
    Maxim Riabichev
    PC Software Support Engineer
