Force EOAT Parallel to a plane
T800_412
Hello, apologies for non specifics, as I am just stepping into the ABB world, however I am a long time automation engineer.
Problem: We have several occurrences where EOAT is colliding with stationary objects when axis 5 is rotating unexpectedly at a pickup point for parts. The parts are at various positions along a single plane (i.e. 8 nests aligned on a shelf) and the robot is supposed to go to pick or place parts to/from these nests.
Question: Is there a way to add something to the program to force the orientation of axis 5 to be parallel to the shelf plane once the EOAT distance from the robot base is greater than (i.e. 500mm), thereby preventing axis 5 rotating and causing collisions when it is near the shelf?
One theory I heard for this situation happening is the robot is trying to take the shortest path to the next nest, because the type of move instruction used is not formatted for a specific path.
What type of move instruction are you using? MoveL, J or MoveAbsJ?Lee Justice0
In the motion parameters you can set a limit of rotation for each axis0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
