Uinumentry on omnicore
Tompanhuhu
Sending an answer to a uinumentry event with PC SDK dosen't work if the answer has a decimal in it.
Sending 10 works, sending 10.5 dosen't work.
Program execution continues without changing the result.
I'm running RW 7.2 with PCSDK 2020.4 (Latest I could find)
☑️2024 - RobotStudio® User Group
UINumEntry only works with integers0
Hello.
The UINumEntry should work with integers as well as floating numbers, depending on weather or not you use the /AsInteger property.
There is most likely a bug that creates your issues, but let me get back to you on that once I can confirm it with R&D
—Nils OlofssonPC Software Support Engineer1 -
I stand corrected, thank you for clearing this up Nils0
I managed to recreate the same behaviour in robotstudio using the built in operator window feature. That one fails to work with decimals aswell. RW7.2 / RS2021.1.1NilsOlofsson said:Hello.
There is most likely a bug that creates your issues, but let me get back to you on that once I can confirm it with R&DSystemintegrator - Web / C# / Rapid / Robotstudio
Hello.
Did you create the floating number with a comma? It has to be a dot.
—Nils OlofssonPC Software Support Engineer0 -
It's not possible to write a "." in robotstudios operator window. Only comma.NilsOlofsson said:Hello.
How am i suppose to write a floating number with a dot?
Also if we go back to the C# program i'm sending a double value to the sendAnswer method.
I don't specify if it's a comma or a dot. This should be done in the PCSDK library when communicating with the robotcontroller?Systemintegrator - Web / C# / Rapid / Robotstudio
Hello @Tompanhuhu.
After some more investigations we have confirmed that it is indeed the "," vs "." problems that creates this issue.
To avoid this you can set the culture settings for the current thread in c# like his:
System.Globalization.CultureInfo.CurrentCulture = new System.Globalization.CultureInfo("en-UK");
You could also set the regional settings in windows to English if you want to.
Please note that you will have to make sure that the input value uses the "." and not ",".
We have also reported the problems with the Operator Window but i as of now I have no updates regarding that.
It solved the issue thank you Nils.Systemintegrator - Web / C# / Rapid / Robotstudio
- 88 OmniCore
- 42 AppStudio
