Worldzone Power On event
When i restart my system, (or swith on/off the power) my_power_on routine is not fully executed,
Down below you see the picture. The pointer is stuck at WZLimSup block1.
Other worldzones are not activated.
Where do i do wrong?
I spent 5 hours here, a little help would be great!!
Thank you!!!
Thank you!!!
You have block1low, block1low, there is no size defined because you used the same pos. Use block1low, block1Up.Lee Justice1
