Difference between simulation and RAPID execution
fross
When using a virtual
station, what are the exact differences between running the simulation
(Simulation tab / Play) and executing RAPID (RAPID tab / Start) apart from the
paths and targets that may not be in sync?
Smart Components seem to doing their jobs
even when the simulation is started from the RAPID tab. Mechanisms do not seem
to be animated though.
Hello.
the play button in the Rapid tab starts the VC but not the simulation. Pressing play in the simulation starts the simulation and the VC's you have chosen through the simulation settings tab.
The synch between rapid and the station is not affected by the play button unless you run synch and play.
The code that will be running on the VC is always going to be the one from rapid.
—Nils OlofssonPC Software Support Engineer0
- 367 IRC5
- 858 RAPID Programming
