Can't import CAD geometry
I am trying to import some parts and assemblies from Inventor (and Creo / Solidworks). I see lots of tutorials for this on youtube, but when I try I do not see the files in the explorer.
I am using RobotStudio 2021.1.2. I've tried both on company license and Student license, as I thought that was the issue. The manual says it should be possible.
Any ideas?
Any ideas?
What are the file extensions? It may be that you need a license for the converter.
Look in options, click on licensingLee Justice0
lemster68 said:What are the file extensions? It may be that you need a license for the converter.
Look in options, click on licensing0 -
We usually have our designers convert the files to stp, step, for us to be able to load.Lee Justice0
lemster68 said:We usually have our designers convert the files to stp, step, for us to be able to load.0
STP (step) is the "native" RobotStudio CAD format, all other formats require a CAD Converter.
These are an additional option, you select the one(s) you want to be able to use.
The only exception to the above is an Authorized Value Provider RobotStudio license which includes all CAD convertors.0 -
graemepaulin said:STP (step) is the "native" RobotStudio CAD format, all other formats require a CAD Converter.
It may be the school license also has all CAD convertors enabled as well - but I thought it was only the AVP license.
Also I think the special free license during 2020 had all CAD convertors enabled,0 -
graemepaulin said:It may be the school license also has all CAD convertors enabled as well - but I thought it was only the AVP license.
I recon it is not a good idea to set things up in an older version with the CAD-converter and import it. It would also lose a lot of the functionality.0 -
ACIS (.sat) is the native CAD. Step needs an optional convertor.
Yes sorry SAT is the native CAD system - sorry for the confusion0
Issue fixed, it was a licensing issue.0
- 339 IRC5
- 67 OmniCore
- 838 RAPID Programming
- 17 AppStudio
