EGM timing synchronization with external vision system
john_LRW
Thanks,
The output data for the EGM sensor protocol is very well documented in the Application Manual - Externally Guided Motion (p31)
https://abb.sluzba.cz/Pages/Public/OmniCoreRoboticsDocumentationRW7/Controllers/RobotWare/en/3HAC073318-001.pdf
@xerim, thanks for the quick response. but it looks like I cannot get the answer from the manual. let me give an example about my question: Assume, I have a vision system PC which sends EgmSensor data package to robot, the time stamp within the EgmSensor is recorded based on PC/sensor timer; The robot send EgmRobot data to vision system with the time stamp based on robot timer. Because we are using 2 different timers, so we cannot calculate the time difference between the 2 time stamps. my question is how we can sync the 2 different timing system?0
When using a vision system with Pickmaster 3 there is a time synchronization service between the PC and the controller.
I do not know much more than that - it may be part of PickMaster or it may be a Windows service...
@graemepaulin, thanks! we tried PTP but it was neither accurate nor stable. I think it will help a lot if ABB can add a timing IO signal.0
