EGM timing synchronization with external vision system
                    john_LRW
            Thanks,
            The output data for the EGM sensor protocol is very well documented in the Application Manual - Externally Guided Motion (p31)
 https://abb.sluzba.cz/Pages/Public/OmniCoreRoboticsDocumentationRW7/Controllers/RobotWare/en/3HAC073318-001.pdf
            @xerim, thanks for the quick response. but it looks like I cannot get the answer from the manual. let me give an example about my question: Assume, I have a vision system PC which sends EgmSensor data package to robot, the time stamp within the EgmSensor is recorded based on PC/sensor timer; The robot send EgmRobot data to vision system with the time stamp based on robot timer. Because we are using 2 different timers, so we cannot calculate the time difference between the 2 time stamps. my question is how we can sync the 2 different timing system?0
            When using a vision system with Pickmaster 3 there is a time synchronization service between the PC and the controller.
 I do not know much more than that - it may be part of PickMaster or it may be a Windows service...
            @graemepaulin, thanks! we tried PTP but it was neither accurate nor stable. I think it will help a lot if ABB can add a timing IO signal.0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
