RRS-II
What is RRS-II PowerPac? When RS 5.08 loads initialy I get an error saying "No valid license for RRS-II PowerPac can be found"
  • Hi
    This is an RS PowerPac that normal users don't have to care about.
    Simple explanation: used when you want to simulate ABB IRC5 robots in another sim software.
    So just ignore that message, at least I do image
    Per Svensson
    Consat Engineering
  • Hi
    If you want to get ride of the message you can just create a new folder in the addins folder and move the RRS2.dll to that folder.
    Addins normally found here if you haven't changed where to install RS
    C:Program FilesABB Industrial ITRobotics ITRobotStudioBinAddins
    Per Svensson
    Consat Engineering
