S4C plus multi move
S4C+ does not have multi move. If you have two controllers and two robots, that is not multi move.Lee Justice0
Ok my mistake maybe you can explain how to connect electrically
my irb6400r has factory ware options I thought it was multi move must be multi tasking I’ll have to check my options
irb140 standard options same with irb6600 irc5 device net slave with some extra options ut nothing specialwhat I’ll like to do is connect both robots to work in same work space in synchronisation working on same object
Irb6400r with irb140 or irb6400r with irb66000 -
Please clarify "work in same work space in synchronization working on same object " = the robots only have to keep out of each others way?0
HI I use Robodk to program both robot unfortunately the post processor saves the program only for one controller taking account that both controllers are linked having one external controller
I've tried several ways to connect both s4c plus controller they just won't connect with the expansion card in both
Today I’ve tried replacing the rectifier from the irb6400R
to combo rectifier and driver DSQC 358C DC2 it didn’t work it looks for the
DSQC 345C DC4I’ve replace back with old rectifier now I’m having error 38600 incoming voltage to dc link too low on DC link A2 single phase missing
I’ve check the incoming mains on all 3 there’s power
I’ve check the motor contactor replay no kinking in
Strangely I didn’t remove the A2 drive
I’ve checked the fuse as picture that’s fine
Mostly it’s a fuse some where
I’ve tried changing DSQC 509 and DSQC 504 boards still no luck
Any ides for to fix it I’ve given up on trying to integrate a second drive cabinet I need to fix current issue it went to fault after trying to change the rectifier to a rectifier driver combo placed to old rectifier back in then Error 38600 started
- 365 IRC5
- 84 OmniCore
