3D-Printing : TCP Speed setpoint for extruder via Analogoutput
I'd like to use the TCPSpeed3DP as speed setpoint Anaolg Out for an extruder.
Therefor I added a module and programmed a dedicated procedure. Rapid OK, but errors/issues when starting the program:
MODULE T_ROB1_EXTRUDER_IO_3DP
    !Scale actual TCP speed (from PrintL command attribute) and link to Local_IO Analogout 1
    PERS Num aoTCP_Mult:=1000;
    PERS Num aoTCP_Div:=1000;
    VAR Num aoTCP_Scaled;
    PROC Extruder_SpeedSetpoint()
        !aoTCP_Scaled:=aoTCP_3DP*aoTCP_Mult/aoTCP_Div; ! Scale TCP speed
        !Local_IO_1_AO1:= aoTCP_Scaled; !Push to analog out 1
        Local_IO_1_AO1:=aoTCP_3DP;!Push to analog out 1
ENDMODULE
Any comment on what is wrong or a better way to link and scale the TCPspeed to an Analogoutput is very much appreciated.
