RWS with a real controller (OmniCore)
Hello, I'm trying to use the RWS to comunicate with a REAL OmniCore controller.
As first I requested the mastership (or the rmmp in manual) but I obtained the following error:
requests.exceptions.SSLError: HTTPSConnectionPool(host='155.185.56.242', port=443): Max retries exceeded with url: /users/rmmp (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate (_ssl.c:1131)')))
Hello there,
RWS on OmniCore doesn't accept Self-Signed Certificates.
Once you get your hands on a Trusted CA Certificate, you can upload it to the controller via RobotStudio as long as it's in the .PEM format.
I believe you can generate a CA Certificate via https://letsencrypt.org/Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer1 -
Thanks for the reply. I have no experience with certificates so I'm trying to find out about it. I'm trying to generate the certificate via command line from a Linux terminal. Assuming I have generated the correct certificate, where should the certificate be uploaded? Under controller - properties - manage certificates I have the following tab.
Do you have a standard procedure to generate the correct certificate? because via https://letsencrypt.org/ is not so clear.
Thanks0 -
Hello andreacarl6,Unfortunately, I haven't tried this myself yet.
All I know is that you need to replace the self-signed certificate in rws_store with a trusted CA certificate.
Make sure it's in .pem format, meaning the file should contain RSA Private Key and the Certificate in one file.
So it should look something like this:
------------BEGIN RSA PRIVATE KEY-----------
Bunch of letters and numbers
------------END RSA PRIVATE KEY------------
------------BEGIN CERTIFICATE--------------
------------END CERTIFICATE----------------
Perhaps you can find a youtube guide on how to work with letsencrypt?
Good luck!Best regards,Maxim—Maxim RiabichevPC Software Support Engineer0 -
andreacarl6 did you manage to get the CA? I'm facing the same problem at the moment.0
I solved the problem: the certificate is not needed. Just disable certificate verification when creating the session. If you use Postman to test the services do as in the image. Since I use the services through a Python wrapper I have set the “verify” parameter of the session to FALSE. All it’s working perfectly.
Thank you for sharing this information with the community @andreacarl6!
For testing purposes I'm sure this will come in handy for many users out there.
However, please consider the security implications if you decide to take this route in a production environment.Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0 -
Of course!, in a production environment it's essential to use a certificate. Thank you for the clarification!0
andreacarl6!
That helped a lot.0 -
Just wanted to add to this post that it is not currently possible to fetch the certificate thumbprint via RWS, but it is possible via RobotStudio (trust_ca_store -> yellow selection):
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 824 RAPID Programming
- 9 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
