My simulation will not run
great
Hi there,
I am new to robostudio and my simulation will not run as soon as I create a virtual controller.
When I run the simulation before creating a Virtual Controller from layout, the LineMover moves the object normally but as soon as I create a Virtual Controller the object does not move and the simulation stops by itself. But I did not experience the same problem on the previous (different) PC I was using.
https://www.dropbox.com/s/zx2k14p6ja2sfnl/Solution1%20-%20RobotStudio.mp4?dl=0
Thanks.
Thanks.
Hello there,
Can you provide a screenshot of your Simulation Setup please?
Thanks.—Maxim RiabichevPC Software Support Engineer0 -
Hi Maxim,
Thanks for replying.
Please find attached the photos of the simulation and its errors.
Thanks.0 -
Also I would like to mention that the photos is just to show the errors. I actually want to build a system with a pick & place feature of objects from one conveyor to the other. As I have done it before when I was using robotstudio on a different machine and it was working fine, I even used the collaborative robots without issue.Now I am using a laptop and the new system I am trying to build is no longer working.
- SmartComponents are not working;
- Robot is not moving to defined targets;
- Etc...
So if you could help me solve it or at least explain to me why is that happening, why it worked before and now is no longer working, I would really appreciate it.0 -
Did you have a trial license on that other machine? And what would the license status be on this new machine?Lee Justice0
Yes I did have a trial licence on the previous machine and I am using trial on this new one.0
And the trial has not expired?Lee Justice0
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
