Picking up an object - 180 degree rotated
popoff_1
popoff_1
edited October 2021 in RobotStudio
how the gripper attach an object? I mean does the gripper attach the object at his origin? Because when I try to pick up an object, see picture, when the gripper receive the I/O Signal to pick it up, the object is rotated by 180 degree. See picture. Why is the part rotated 180 degrees when it is picked up? Thank you!
  • graemepaulin
    graemepaulin ✭✭✭
    Answer ✓
    Try selecting keep position instead of update position - this will keep the object in the same place relative to robot (but move with the robot)
  • Are you using Events or a smart component?
  • I have used the EventManager and have set DO_01 to 1 when the grippger is picking up the object. In the rapid code I have written like this: SetDO DO_01,1;
  • popoff_1
    popoff_1
    edited October 2021
    Ok now it works. Thank you very much! :smile:
