Cannot Create Module
I can load a module but cannot access it, change it. I try to create module and it comes up with this message. The workcell is a copy of my workcell and it works on my workcell. The customer is having a problem with his workcell.
Are you using the rapid editor or the virtual pendant? What are the attributes of that module?Lee Justice0
Creating through rapid in robot studio
OK, that is what create module looks like, what does it look like when you load it?Lee Justice0
These are the attributes I create the module with. It immediately comes up with this error and will not create the module. When I load a module it shows up but when I try to modify the name in the rapid editor it will not allow me to apply changes and comes up with this error.0
When you load the module what are its attributes?Lee Justice0
Sorry Lee I'm new to this. Been a long time Fanuc guy. I'm assuming that you are asking what the attributes are when I pull up the module in rapid. I created the file on my workcell. I had the customer load the pack n go that I created from the same workcell which was created from a backup of a system on our floor. I can create the module on my system, but when I try to load onto his (same workcell) I get this error and cannot create any modules. I'm wondering if I'm dealing with a licensing issue??? Again, right now the workcell is created from a backup of a dual multi move robot that is on our floor. In the workcell it shows the serial number of that particular robot. Is that why I'm having problems?
Maybe it is somehow corrupt. Open it in a text editor and see if anything seems strange. How big is the module? Can you post it here?Lee Justice0
- 360 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
