UIMsgWrite - What am I doing wrong???? Cant get the message to clear from TP
What you have looks correct according to the manual. Try TPShow.Lee Justice0
I think that the Robot search and because you are using \SStop, it stops the executing when position have been found. Have you tried other optional parameters other than \SStop?0
@jmf - we have commented out the Search to see if this has an affect, unfortunately not.
