Export Robot to step in different poses
Einevik
There is no way to export the robots found in Robotstudio to step, i am afraid. The robots in the ABB library in RobotStudio does not have the CAD data attached.
If I need to do it, I will download the step files from ABB website for the given robot and actually contstruct the robot myself using the create mechanism wizard. I then use the abb library robot to see what the joint constraints are.
Hope this helps you.1 -
Thanks!0
You can get different formats of 3D CAD models from ABB Robotics home page. Industrial Robots Portfolio | ABB Robotics For instance of IRB1200, Click the link : ABB Robotics industrial robot IRB 1200 - IRB 1200 | ABB Robotics (Industrial Robots Portfolio | ABB Robotics)0
- 858 RAPID Programming
