IOT Gateway Doesn't see all RAPID variables
Recently connected IOT Gateway to a IRC5 running RobotWare 6.05.02. I then have an ignition gateway connected to the IOT Gateway for an HMI. I can see any variables that are defined PERS but not VAR or CONST.
I would expect VAR or CONST to at least be available as read-only. Is this typical with all versions of RobotWare?
