proc argument
pab
Hi!
Please tell me why it works with num, but does not work with string?
it work:
PROC main
test 1;
test 2;
PROC test (num x)
IF x = 1 THEN
ELSEIF x = 2 THEN
ENDIF
it will be error:
PROC main
test first;
test second;
EMDPROC
PROC test (string x)
IF x = first THEN
ELSEIF x = second THEN
ENDIF
it work:
PROC main
test 1;
test 2;
PROC test (num x)
IF x = 1 THEN
ELSEIF x = 2 THEN
ENDIF
it will be error:
PROC main
test first;
test second;
EMDPROC
IF x = first THEN
ENDIF
Best Answers
Don't use "test" as proc identifier. It looks like it's reserved.
This syntax seems to work:
PROC abc(string x)IF x="first" THENELSEIF x="second" THENENDIFENDPROCPROC abcd(num x)IF x=2 THENELSEIF x=3 THENENDIFENDPROC
Also your syntax when calling:
Test "first";
To indicate that it is passing a string into the procedure.
And, same as Maxim's example, you need to have the quotation marks to indicate string data type:
IF x = "first" THEN
UNLESS it is the name of an already declared string data.Lee Justice0
The quotation marks. Here's what I missed when working with string. Thanks!lemster68 said:Also your syntax when calling:
Test "first";
IF x = "first" THEN
p.s.
I used "test" just for the sample code0
