Recent update(March 2021): Download Virtual SmartGripper 2.3.01
ABB_YuMiGuide
edited October 2022 in RobotStudio
Dear All,
You can now download the Virtual SmartGripper. Some details are explained below.
  • What is the Virtual SmartGripper?
               -> SmartComponent for RobotStudio packaged in an Add-In
               -> Firmware/ Graphical simulator for ABB's SmartGripper
  • What can the Virtual SmartGripper do?
               -> Manually move the gripper fingers
               -> Manually attach/ detach objects to the servo fingers/ to the vacuum cups
               -> Calibrating the finger servos
               -> Fully supports Smart Gripper RAPID functionality during simulations and during usual control executions.
               -> Also controllable through teach pendant
  • How can it be installed?
               -> Install the package through RobotStudio's Add-In Tab.
If you have any additional questions/ feedback, please post them here.
Regards,
ABB_YuMiGuide
Post edited by FlorianKnecht on
  • Elinh
    Elinh
    edited September 2020
    Elinh wrote:
    """I've tried to use the gripper on YuMi but I can only make it work on one arm.
    It is only the arm that I attach to first that works. So it's not particulary right or left arm.
    Someone else with the same problem?"""
    Answer: This question depends on an older Version, it is fixed now.
  • Did you make it from SDK?
    Can you please share your source file?
