Routine File (Help)
Amelie
Hello everyone. I want to perform an action on a Routine file. I want the Robot to stop automatically when a signal that I specify in the Routine File (Across the Whole Loop) does not output. For example, with a switch that sends a digital output, I want the Robot to stop when the air outlet is insufficient. How can I do that?
You could program an interrupt. Or you could make it a system input which would make it stop.Lee Justice1
Firstly, thank you. I don't know exactly how to do it. Can you share an example or manual on this?
The easiest for you would be the system input. Read up on that in the System parameter manual.Lee Justice1
Thanks.0
