Custom system parameter
I am creating a RW Add-in and I wonder if it is possible to have custom system parameters for some of the setting for my Add-in.
Today all settings are stored in persistent variables, and while that works fine, I just think it would be more clean to have system parameters for some of my settings.
For now I use RW 6, but if there is a difference I am also curious about RW 7
//Markus Näslund
You can create custom systemparameters in the system with your addin.
It's well explained in the manual with examples of different datatypes (picklist, bool, array).
I have attached the manual for you.
I also attached 3HAC070207-001.pdf which is for RW7.
To read the values of these parameters you use standard rapid instruction ReadCfgData.
Good luck!Systemintegrator - Web / C# / Rapid / Robotstudio
Thank you,Tompanhuhu said:You can create custom systemparameters in the system with your addin.
Good luck!
However, I am not sure if I think it is very well explained at all. I had already checked the manual before asking here, and I have tried making some parameters with guidance from the manual, but I just can't get it to work.
Let's say I want to create a parameter that lets my addin code know if and how a certain procedure should run.
We can call the parameter RunProcA and the value could range from 0 to 2 depending on how the procedure should run. Now from the manual I figured out that the parameter should look something like this '-name "RunProcA" -value 1'
So, here are the specific questions that I cannot find in the manual.- Which domain do I use? Is there a specific one that I must use or can I choose freely? The ones I have tried does not work.
- Which type? Again, can I just name my own type or must I choose from existing types? I always get Illegal type name - error if I try to set my own type
//Markus Näslund1 -
Hi Markus, please see attached photo's if it's something like this you are looking for.
☑️2024 - RobotStudio® User Group-1 -
PROC:CFG_1.0:6:0:: # HUHUH_SETTINGS: -name "Tompanhuhu's string" -HuhuhSelectList "TOMPANHUH"\ -RunningSignal "doVirtual_02" -StartSignal "diVirtual_4"Thats the PROC.cfg file when exported from the controller.
To answer your questions.- Which domain do I use? Is there a specific one that I must use or can I choose freely? The ones I have tried does not work.
I can even create my own topics.
Types can be bool,string,int,double,combobox or radiobutton selection.
Hi Markus and Tompanhuhu,I am facing the same problem as Markus.I have checked both pdf's "3HAC051193-001" and "3HAC070207-001" and could not even find anything about how to let the controller know my user-defined cfg-domains or cfg-topics.Which chapter is it in?Having simply copied the "HUHUH_Settings" to the PROC.cfg and attempting to load it to a RW7 VC, I got the ELOG message "120019 missing instance name in cfg file"Thank you.
I solved it in the end by a lot of trial and error and by dissecting different function packs. I can dm you my solution and you might be able to solve it from that. But I never found any documentation on how to do it, I don't think it is intended.
Also, I have not tried this solution on RW 7, so it might not work for you at all?
Br
Markus//Markus Näslund0
