Missing Reset Configuration Option
I'm currently running RobotStudio 2021.4 and I've found that there is no option to reset the configurations on a path. As noted in the RobotStudio Operating Manual, I should be able to right-click a path, select Configurations, and select Reset Configurations.
When I attempt to do this, I find there is no "Configurations" option in the menu, only "Auto Configuration".
Is there a reason this feature isn't available? I'm aware that I can make this option available with a keyboard shortcut, but doesn't seem to change the target/move instruction icon as the manual suggests.
Thanks in advance
  • Maxim Riabichev
    Answer ✓
    There are many "correct ways" to generate paths with appropriate configurations. The one you mentioned is one of them!
    Maxim Riabichev
    PC Software Support Engineer
  • Hello JolonB,
    I've just searched through the RS 2021.4 Operating manual and I can't seem to find that section. What version of the manual are you looking in, and what page is that excerpt taken from?
    Thanks!
    Maxim Riabichev
  • Hi Maxim,
    It looks like I might be using the manual for RS5.14 on page 405 (link). That explains why it's different.
    I think I figured it out too (by looking at the 2021 manual this time). By right-clicking a target, I can set its configuration and then apply it to the entire path by running Auto Configuration. Is this the correct way to set the configuration of a path?
  • That clears things up. Thank you for your help!
