Turning MoveAbsJ movement into Targets
If I run a simulation that contains a MoveAbsJ instruction, is there some way to turn this movement into targets. Perhaps 3 or 4 points within the movement?
ENDGOAL: Eliminate MoveAbsJ & replace with MoveLs for those targets.
  • lemster68
    lemster68 ✭✭✭
    Use function CalcRobT
    Lee Justice
  • Thanks Lee, I overlooked that in the Technical reference manual.
    BR,
    J H
  • Revisiting this, CalcRobT isn't the function that would work. I would like to create multiple targets during a moveabsj movement & store it somewhere so that I can use the targets.
    I think CRobT & a loop triggered by I/O would help. Im not sure where to place or call this loop
