Share variables between 3+ RAPID Tasks
Hello community,
I am working with an IRB 2400/16 and I am developing an applications which uses 3 tasks: T_PAR, T_EXTRUDER, T_ROB1.
T_PAR is a tasks which communicates via socket for getting a data message and save the message in 8 variables: 6 for the pose and 2 for speed and extrusion parameter.
T_EXTRUDER: takes the extrusion parameter from the reading in T_PAR and makes a communication socket with another device.
T_ROB1: Takes the pose data from T_PAR and executes the motion.
Question: the variables are saved in SYSTEM module and shared installing the module in the autoloading. But they are only shared between T_PAR and T_EXTRUDER. Is it normal?
Thank you in advance
Fede
Best Answers
  • lemster68
    lemster68 ✭✭✭
    Answer ✓
    The Data must be declared as PERS in all tasks which must share it.
    Lee Justice
  • Newman
    Newman
    Answer ✓
    Kappa95 said:
    But with PERS the data can be modified between all tasks?
    Yes as long as you declare data as PERS and with same name you can read/write the data in all tasks.
    I usually only to declare the "initial value", the :=, in one of the task, e.g.
    T_ROB1: bTest:=TRUE;
    T_ROB2: bTest;
    T_ROB3: bTest;
    David
    Swedish freelance ABB robot programmer
  • But with PERS the data can be modified between all tasks?
  • yes
    David
    This is not the case when the module is installed shared, all data in an installed shared module are shared between tasks. Even data declared as VAR.
    //Markus Näslund
