Is it possible to use PCSDK to get RAPID memory?
KennyJiang
mod
Is it possible to use PCSDK to get RAPID memory like that shown in system info on the TPU?
hi,
Possibly it is possible to find it with something like this, but I am not able to test on an RC
var mgr = new DeviceManager(_controller);
foreach (IDeviceNode child in mgr.GetChildren())
{if (child is IPropertyNode)
IPropertyNode prop = (IPropertyNode)child;}
—Doyel JosephPC Software Support Engineer1
Hi Doyel,
I tried your code on an RC. 2 IDeviceNode are found with name "Hardware devices" and "Software resources", but neither is IPropertyNode. Is there anything else to try?0 -
Hi Doyel again,
After understanding your method, I got the memory information. Thank you very much!
I also wonder if it is possible to get the serial number information by PCSDK. Or how to get "Controller properties" or "System properties"?0
