Siemens S7-1500 ProfiSafe, Profinet, TCP/IP, two controllers, same switch
Hi everyone.
I have an upcoming project where both PLC and robot will act as Profinet controllers.
We have done similar setups before with tcp/ip, profisafe and profinet mixed on the same switch and it worked great, but those times robot hasn't been PN controller (888-2).
This time we wan't the robot to be controller of Fronius welder with option Profinet device, and at the same time the robot should act as a device to Siemens S7-1500 FailSafe cpu.
Has anyone done something like this? When reading Profinet Application manual I get a feeling that it should work.
David
Swedish freelance ABB robot programmer
David
Update:
It worked fine.-----------------
David
