How to fix the activation wizard that is currently disabled?
Hi Shwan_Lee,
First check and ensure the time and date are set correctly on the PC then do the following:On the computer where this error is occurring run cmd.exe (command prompt.)Execute command below which will delete the 7.x folder:RD /S /Q "%programdata%\ABB\RobotStudio\7.x"Execute command below which will recreate the 7.x folder and reinitialize the license storage:"%programfiles(x86)%\ABB\RobotStudio 2021\Bin\RobotStudio.Installer.exe" -InitLicenseStorageAt this point when you start RobotStudio the error should not appear and you should be able to access the license activation wizard.
Liam0 -
Dear Liam,
Thank you for your beautiful answer.
You will must deserve novel prize.
Thanks.0
