Abb Integrated vision without cognex camera
atef123
Hi everyone,
I am new to integrated vision
I work on a project to detect objects with an irb 1200 and a camera, I know the ABB robot came with its own solution (Cognex camera) but I want to use another camera.
Thank you for your help in advance
ABB Integrated vision won't work without a compatible abb camera.
I have heard from abb that the rebranded cognex cameras have a special firmware making them work with robotstudio, so a standard cognex camera won't connect with integrated vision.
(Please correct me if this is wrong)
If you want to use another camera you have to use a different software to handle the camera.
This is true of the cameras to work with Pickmaster.
From the Integrated Vision Manual:The purpose of ABB’s Integrated Vision system is to provide a robust andeasy-to-use vision system for general purpose Vision Guided Robotics (VGR)applications.The system includes a complete software and hardware solution that is fullyintegrated with the IRC5 robot controller and the RobotStudio programmingenvironment. The vision capability is based on the Cognex In-Sight® smart camerafamily, with embedded image processing and an Ethernet communication interface.
RobotStudio is equipped with a vision programming environment that exposes thefull palette of Cognex EasyBuilder® functionality with robust tools for part location,part inspection and identification. The RAPID programming language is extendedwith dedicated instructions and error tracing for camera operation and visionguidance.1 -
Thank you all for your help0
- 367 IRC5
