40304 File access error
When attempting to backup to the controller or through Robotstudio we are getting the below errors. Any ideas what causes this?
Robot: IRB 1600 Flexarc
Robotware: 6.06.00
165131 I Operational 10230 Backup step ready 2022-04-06 08:46:50 The backup step Prepare is ready.
Robotware: 6.06.00
165132 I Operational 10231 Backup step ready 2022-04-06 08:46:50 The backup step Configuration is ready.
165133 E Program 40304 File access error 2022-04-06 08:46:50 Task T_ROB1 is trying to access file /hd0a/1600-105743_FlexArc/INTERNAL/RAPID, but failing.
165134 E Operational 11236 Backup error 2022-04-06 08:46:50 Error during the backup of Task. Write error.
165135 E Operational 11261 Backup removed 2022-04-06 08:46:50 Error while creating a backup at path: /hd0a/TEMP/backup.073343
Are you running short of storage space of SD card? (the controller's)Lee Justice0
Hi Lemster, not running short on space. We found this issue on more than one robot controller, so we are now investigating recent code added to these particular machines.0
This is a really off chance here, but did you modify the system parameters to include files or folders not normally included in a backup? I tried that a few years back, and found that it did not work. May have even been the same error, if not, similar.Lee Justice0
Thanks! Actually, that is exactly what we did. We created .txt file to write 3 lines of text every time a tool check was completed. This is simply to time stamp the process so we can quickly check when it was last done.
Upon digging a little deeper into this it looks like there is another event message 41679 being triggered, buried in other alarms... See below snippets and the code in bold we will try and add.
Open "HOME:"\File:="R1_BE_ToolCheck.txt",R1_BE_ToolCheck\Write;
Waittime 0.5;
Write R1_BE_ToolCheck,"R1 Bullseye last checked:";
Write R1_BE_ToolCheck,R1_BE_ToolCheck_date;
Write R1_BE_ToolCheck,R1_BE_ToolCheck_time;
close R1_BE_ToolCheck;
Waittime 0.5;
It is recommended to use the Close instruction before the Open.Lee Justice0
But if you write it to the HOME directory it ought to be included in the backup. As such, it would not be necessary to add the parameter to include that file.Lee Justice0
Thanks, so close before and after like the below?
Waittime 0.5;
Waittime 0.5;
Waittime 0.5;
Uh, maybe if there is still an open com device active to that file. But yes, Make sure it is closed before opening and close when you are finished writing. We will see, won't we?Lee Justice0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
