IRB1200 rslib no longer in RS2022
I was able to do a workaround by creating a new empty station, add an IRB1200 and then export a rslib from that.
One strange thing was that I had another project with an IRB1200 which I could open without problem.-----------------
David
Now I was able to locate the libray here. There are a lot of unnamed library folder.
David
I have the same problem...1
Had this problem to locate the lib of IRC5 Single Cabinet. After upgrading from RS2022 to 2023, the lib folders were not migrated/copied from 2022 to 2023 (maybe I messed up when installing?). Found the lib files on
C:\Program Files (x86)\ABB\RobotStudio 2022\ABB Library\Equipment
All (well almost) library components have been moved to distribution packages so they can be distributed and updated independently. You can install packages manually from Add-Ins/Gallery, or they will be installed automatically when needed.
The packages are located under C:\ProgramData\ABB\DistributionPackages2, but normally you should not need to access them manuallyJohannes Weiman
RobotStudio Team, ABB Robotics0
