How to use "simulatemenu" in abb
When I am running the program in manual, it stops and asks if I want to simulate the wait time. Apparently "SimulateMenu" can be used to turn this warning off.
How exactly do I use this command? Is it in the modue code? I searched for settings and could not find it anywhere.
Thanks for your help!
Robot Studio V2022.1
Hi gczerkawski
In Configuration -> Controller -> General Rapid, there is a SimulateMenu Parameter,
Good Luck,
Harry0
Thank you for your help - greatly appreciated!Forge_Engineering said:Hi gczerkawski
Good Luck,
Harry0
