timeout problem
ryan
I have a problem about creating a new sytem from backup. When I try to create from backup with true RW version timeout occurs. "Starting" displays on screen longer than normal, then "Error - timed out" displays and a dialog box says "There was a problem starting the virtual controller".
This is from logfile:
2007-03-16 18:32:22 : CLgVCHelper::Shutdown(): Timeout! File:.LgVCHelperImpl.cpp:297
I do the same things with another computer (the same backup and RW version) and RS creates the system with no error.
Can anyone tell me where the problem is?
Onur Altunta_ / Turkey
ryan2007-3-17 14:49:40Onur Altunta? / T?rkiye
I would guess that this is a DualCore problem. There are a couple of threads in this forum about it and here is one http://forums.robotstudio.com/forum_posts.asp?T ID=1183&PN=1Per Svensson
Consat Engineering0 -
I disabled Dual Core and problem solved. Thank you so much for your help.
Onur Altuntas / Turkey
Onur Altunta? / T?rkiye0
