Go To position - not working
With the Flex Pendant I highlight the position, then Debug, and select Go to position. However, it the robot does not move to this position. Is there something I am missing?
IRB14000 YUMI
IRB14000 YUMI
You need to be in the jogging screen, and tap Go To as below.
Ensure you have the correct tool and workobject (if used) selected in the jogging screen.
The Go To uses these as the co-ordinate systems to use with the Robtarget...
This opens a new screen where you can select the position...
Only works for named Robtargets not inline (*) Robtargets
I never used the Yumi, but in other robots you use the jog screen to go to or move to position.Lee Justice0
lemster68 said:I never used the Yumi, but in other robots you use the jog screen to go to or move to position.0
I opened the Program Editor, and selected the position, then selected Go To position. I hold down the Go To button, and nothing.
I don't get it - shouldn't the robot move to the position?
graemepaulin said:You need to be in the jogging screen, and tap Go To as below.
Thank you for the clarification.CONST jointtarget PposStart:=[[58.5188,-73.4665,44.0647,-1.55973,13.5018,-14.7421],[-74.036,9E+09,9E+09,9E+09,9E+09,9E+09]];CONST jointtarget PposInsert:=[[65.9099,-68.1386,28.8881,-0.762834,45.0241,-55.3991],[-97.1017,9E+09,9E+09,9E+09,9E+09,9E+09]];CONST jointtarget PposDrop:=[[53.3995,-68.1223,18.8865,-1.63301,66.5549,-55.2394],[-92.2589,9E+09,9E+09,9E+09,9E+09,9E+09]];PROC main()MoveToHomeR;HalfSyncR;!FullSyncR;MoveToHomeR;ENDPROCPROC MoveToHomeR()MoveAbsJ pHomeR\NoEOffs, v1000, z0, gripRight\WObj:=wobjTable;g_GripOut;ENDPROCPROC HalfSyncR()WaitSyncTask\inpos,sync1,tasklist;!-----------------------------------------wait sync1 - wait until both arms have homed...................................g_GripOut;MoveAbsJ pPosAppr\NoEOffs, v1000, z50, gripRight\WObj:=wobjTable;WaitUntil \inpos, TRUE;!WaitTime 1;MoveAbsJ pPosPick\NoEOffs, v1000, z50, gripRight\WObj:=wobjTable;WaitUntil \inpos, TRUE;!WaitTime 1;0 -
Is it possible to change these jointtargets to robtargets?0
Use the Function CalcRobTLee Justice0
lemster68 said:Use the Function CalcRobTVar robtarget p1;CONST jointtarget pPosAppr:=[[48.6457,-47.2697,63.7466,44.4377,-57.9163,2.44986],[-81.4889,9E+09,9E+09,9E+09,9E+09,9E+09]];p1 := CalcRobT(pPosAppr, gripRight\WObj:=wobjTable;PROC main()MoveToHomeR;HalfSyncR;!FullSyncR;MoveToHomeR;ENDPROCPROC MoveToHomeR()MoveAbsJ pHomeR\NoEOffs, v1000, z0, gripRight\WObj:=wobjTable;g_GripOut;ENDPROCPROC HalfSyncR()WaitSyncTask\inpos,sync1,tasklist;!-----------------------------------------wait sync1 - wait until both arms have homed...................................g_GripOut;MoveAbsJ pPosAppr\NoEOffs, v1000, z50, gripRight\WObj:=wobjTable;WaitUntil \inpos, TRUE;WaitTime 1;
You have left out the end parenthesis.Lee Justice0
lemster68 said:You have left out the end parenthesis.
I did manage to change all the jointtargets to robtargets, just had to go to each one step-by-step and add a new instruction.
Would be nice to know why its not working.0
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
