remove robot
in IRC5
Hello guys, could you please help me with remove robot from configuration. I have one master and two slaves and i need to remove middle robot which is slave.
is it correct that i have to choose this robot in robotware? then delete it then reboot controller and after that make a safety bridge?
Thank you for your advices
Are these real robots or simulation in RS?Lee Justice0
It s real robots0
lemster68 said:Are these real robots or simulation in RS?0
Do you really have to remove it? Could you leave it and just not use it? I know that is wasteful. You would have to remove all references from the MOC.cfg to that robot. You would have to do some rewiring as well. And yes, you would have to rebuild that system minus that robot. Which, actually probably should remove the bits of moc.cfg. This is a multimove system, right?Lee Justice0
lemster68 said:Do you really have to remove it? Could you leave it and just not use it? I know that is wasteful. You would have to remove all references from the MOC.cfg to that robot. You would have to do some rewiring as well. And yes, you would have to rebuild that system minus that robot. Which, actually probably should remove the bits of moc.cfg. This is a multimove system, right?
But I dont have really any idea and steps how to do it. I know that I have to remove robotware I have to uncheck it in drive modules and robots but I dont know anything more0 -
If it has not been delivered yet maybe you can change the order.Lee Justice0
lemster68 said:If it has not been delivered yet maybe you can change the order.
You have me confused, you wrote, "I dont have a cabinet and robot here."Lee Justice0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
