Controller not visible in the Smart component design Tab
Luxrobotic
Hello everybody,
I try to create some Smart components in my station.
But when I want to connect some signal coming from my VC, the controller is not visible in the workspace of the Smart component design Tab.
As well as in the "Add I/O connection" tool box
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
Virtual Controller isn't located there. You can find it in the 'Station Logic' window.
Hi,thanks innebandy for your reply.What do you mean by 'Station Logic' window ?I found this on the forum, you can see the IRB5500_New IO Signals box. This is what I miss in my work space.
RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110
