Event message 50057 - Joint not Synchronized
jmf
Due to constant power failures from our electricity service provider in RSA, my Robot System started up with a System Failure State and the active Event message 50057 - Joint not Synchronized is displayed directly after the power failure.
I cannot access the Robot Calibration option as everything is blacked-out except:
- Backup and Restore. When trying to restore backup it provides error but no reason.
- Control Panel. Inside only Configuration System Parameters & System Diagnostics is active.
- FlexPendant Explorer. Can browse to the backup but does not restore.
- Event Log.
Does anybody have a solution to correct this and to get this System Failure sorted out?
- Event Log.
Have you tried a B-start (use last correctly started image) - you will lose any changes that were not saved since the image was saved (done automatically on power off).
This is under the restart menu (bottom of main menu screen) -> advanced.0
Hi Graemepaulin.graemepaulin said:Have you tried a B-start (use last correctly started image) - you will lose any changes that were not saved since the image was saved (done automatically on power off).
I have and it removed the System Failure state. The Robot Revolution Counters was required to be updated.
Its working now.
Thanks for your response.0
- 364 IRC5
- 82 OmniCore
