3D Printing PP - Extrude Function
in PowerPacs
Hello everyone, can someone help me with the 3D Printing PowerPack.
I've been trying to get the system working properly for some time.
1.) I defined an external axis (extruder).
2.) I set up the station and all devices.
I cannot select the Extrude command under Process Settings. What did I do wrong and how do I fix it?
Similar problem here, but with printing..0
Just to verify, are you using a Virtual Controller with the 3DP RW Add-In installed, where the option "Integrated Extruder" is selected? If not, you need to start with that. There is a tutorial that explains how that is done.Best regards,
ABB Robotics0
